Preset rotation angles
Command
Path
Rotate
Modify
Context menu
The rotate commands provide a number of ways to rotate objects in the screen plane without changing their base location in the drawing. Select one of the preset rotation angles or specify a custom rotation angle.
To rotate at a specified angle:
Select the object to rotate.
Select the command, and then select one of the preset rotations.
Command
Description
Shortcut
Rotate Left 90°
Rotates the selected object counter-clockwise 90°
Ctrl+L (Windows)
Cmd+L (Mac)
Rotate Right 90°
Rotates the selected object clockwise 90°
Ctrl+Shift+R (Windows)
Cmd+Shift+R (Mac)
Rotate Each Left 90°
Rotates each selected object counter-clockwise 90° about its insertion point (or the center of its bounding box if no insertion point exists).
Grouped objects rotate individually.
Ctrl+Shift+/ (Windows)
Cmd+Shift+/ (Mac)
Rotate Each Right 90°
Rotates each selected object clockwise 90° about its insertion point (or the center of its bounding box if no insertion point exists).
Ctrl+Shift+\ (Windows)
Cmd+Shift+\ (Mac)
Flip Horizontal
Flips the selected object horizontally about its center
Ctrl+Shift+H (Windows)
Cmd+Shift+H (Mac)
Flip Vertical
Flips the selected object vertically about its center
Cmd+Shift+H (Mac)
Rotating objects
